6600GT "custom" cooling
slaya
Hey, I have a MSI 6600GT and the fan is very loud to me, I don't want to spend $35 on a Zalman cooler because I don't overclock and won't need that extra cooling..
I was thinking about taking off the metal cover, leaving the current fan in place, and placing an 80MM fan directly to the heatsink..
Is there a way I can place the 80MM fan so that it cools well WITHOUT taking off the current fan (the current fan will be disconected though, I just don't want to void the warranty)
The fan I am thinking of will be an 80MM 32CFM..
I don't overclock, but being a GPU it would still get hot while I play games
Would this work?
You'd be spending that $35 on silence. If silence is important to you, you'll spend that money.
If you do opt for the Zalman cooler in the end, you'll like it. I put one on my 9800 Pro 256mb and it cut my noise levels in half (I'm assuming that you are talking about the Zalman VF700-Cu cooler). My temps: (GPU/RAM) 38C/36C idle, 45C/43C. Oh, a note on my temps: the frequencies are 391/351(GPU/RAM) instead of the usual 380/340; my card runs that way constantly for some reason.
I got the thing for silence. and I concur with Korruption. I think that your idea may work, but i am not sure as to how to go about it.
Tell that to my cheap ass :-P
I'm about to try this, is there something to indicate if it's getting to hot? Would it just lock up or burn itself out? no temp probe on the card..
Huh? I thought all the Geforce 6xxx's had temperature probes built in. You should be able to check it from the driver control panel.
Meh, that was such a waste of time.. I did it, but the fan(s) I had were just as loud, if not louder than the stock fan when pushing a decent amount of air.. I guess i'm just going to purchase the Zalman.
you could go to best buy and get a slot blower fan, and disconnect your fan to your 6600 GT, that's what i have right now working on my fx 5600 ultra, because the fan went bad on it, and it constantly buzzed, and got artifacts in games... but now i don't see it going over 60 C in games
also, they're like $10+
The thing is they would be too loud, 38dBa, If I have to hear that I might as well use stock cooling..
