6600 OC Temps are too high?
zvikasap
Yeah i know that recently there were alot of threads concerning this issue but i'd like to know an answer refering to my own specs.
Anyway i got my 6600 B3 Overclocked to 3000 and the temps on idle are 55 and at load 74 deg.
Considering my cooling which is Tuniq 120 and my case (Thermaltake Eureka) i think the temps are a little bit higher than they should be and im concerned that maybe these temps can cause my CPU permanant damage.
I'd like to point out that i check my temps with core temps and the CPU was running Prime95 for 10 hours without any errors so the system is stable but the question is if its worth the price if theres any.
Here is my spec:
ASUS P5KC
Intel Core 2 Quad Processor Q6600
OCZ DDR2 4096MB Platinum Rev.2 Dual Channel 800MHZ CL 4-4-4-15
XFX GeForce 8800 GTX 768MB DDR3 PCI-E XXX Edition
3X WD 250GB SATA
2X WD 120GB IDE
1X MAXTOR 80GB IDE
Creative Sound Blaster Platinum2 ZS
Pioneer DVR-212D 18X SATA Dual Layer BLACK
Thermaltake EUREKA black
OCZ StealthXStream 600W Power Supply
Windows Vista 32bit
Read in the following posts:
Xtreme Q6600 G0 Overclocking on Air !!! (Pics Heavy & Daily Updates)
http://hardforum.com/showthread.php?t=1212009
*Official* Quad Core Overclock Thread
http://hardforum.com/showthread.php?t=1210562
Q6600 @ 4.1 GHZ
http://hardforum.com/showthread.php?t=1219990
Those Quads (2x E6600) tend to get a little hotter than the E6600.
But 75C is defenitely the max for OC temps.
Donnow how these quads are tightened on the MOBO but I know that my E6600 tightenings suck....so if it's getting lose temps also get higher.
Those temps shouldn't really cause any permanent damage to the cpu.
Of course the overall lifespan would be a bit shorter considering the higher volt required and the increased heat it generates. But it's not like you're going to be using this cpu for that long, is it?
The temps are a tad high considering it is cooled by Tuniq. Have you properly applied TIM (e.g Arctic Silver 5)?
I idle at 40-43 and full load at 60-64, with the fan speed set to lowest. But given that it's a G0, it should be a bit lower.
Have you tried to see how much lower you can go with the vcore without sacrificing stability?
Well its the lowest voltage that my system can run stable on atleast at this FSB.
I did applied the heatsink as it should but i think the main reason for my temps is simply the weather, my room is a small one, something like 2X3 meters and the temp in the room is 30 celcius so its pretty hot in here unless the AC is on and than the temp drops to 22 celcius which is think its ideal.
I think tomorrow morning's ill open up the case and thake another look at the Tuniq just for case.
What is your room temperature and system temperature? Also what is the temp of your GPU(videocard)?
How many fans you have in your case? Intake and exhaust? That's one big fat case and I only see 1 exhaust not including the PSU.
My room temp is usually between 28-32 Celcius, system temp is 43 and the GPU is 70 on idle.
The case has 2 120 fans, one in the front that takes air inside and one on the back that takes air outside.
I think this system is 10 degrees hotter than is should be for all the components, the question is how to lower he temps in an efficient way.
Assuming your heat Sink is mounted correctly I'd suggest you start with some more case Fans. I went from the 3 Stock 120mm low RPM Sleeve Bushing fans to 4 120mm Higher RPM DBB fans and my CPU Temps dropped 5C and my GPU dropped about 8C basically all due to a greater volume of cool air flowing through the case.
Good Luck
Im really considering buying a water cooling system, the prive aint that high and the performance for me will justify it.
I think this will probably be the best solution.
Well that is you problem right there. Your room is HOT. Your system is TOO HOT. Another problem is that you only have 2 fans for your case and the worst thing is that Q6600 and 8800GTX package a lot of heat. Not enough air is coming in and 1 fan can't get rid of the heat fast enough. That temp you're getting is about right and is nothing to do with the seating or the thermal paste of your heatsink with that setting.
Do you have a link to what kind of case that your have? There are alot of the Thermaltake Eureka version and I'm not sure which one you own.
I'm not sure if water cooling is even a good idea since your room is hot. I mean if I were you I'll rather spend $200 on an AC. Water cooling is still using air and room temp to cool.
When im at home ofcourse the AC is on but most of the day im out so its not financial to keep the AC on.
Here is a link to my case at the official website, please note that i removed the front door which blocks the front fan.
http://thermaltake.com/product/Chassis/fulltower/eureka/vc8000bwa.asp
So you're saying that your room temperature is around 28-32 with the AC on?
That's is just a terrible air cooling case. I mean how are you supposed to intake air from the front with the door closed? Or else try attaching 2 120mm fans on the side mess.
If you can afford water cooling, give it a try. But I don't know how effective it's going to be if your room temp is around 30 but no doubt about it that it'll be better than your air cooling right now.
I guess i can afford 250$ water cooling system but i only take this as a final option.
The room temp with the AC on is 22 but as i mentioned above, most of the day im out and the AC is off and then the temp reaches 30.
About the case,the main reason i chose this case was its size and the large capacity of hard drives, too bad i didnt pay attention to the cooling solution in this case which may be enough for cold places but definitely not enough for my place.
The door position is just awful so i simply removed the door so the fan be able to intake air into the case.
I think the best solution for now will be looking for ways to add atleast 2 more 120 fans,one of them directly on the door infront of the cpu and the other one maybe at the upper wall.
Have you at least lapped your heatsink?
