watertown28
- Jan 30, 2007
I am running my cpu at 3.5 ghz atm ( c2d 6700 ) and at load speed fan/everest both are saying my core temps are at 65c load and the cpu temps is at 59 c. What kind of heat can these babies take?
you definitely need better cooling..
got a 9700 zaleams HS on it I dont know if there is anything much better then that besides water but i dont liek idea of liquid flowing over my electronics![]()
65 is OK I wouldn't push much higher than that or you will lose life on your CPU. The core slowdown threshold on a C2D is 85C but they are not recommended to go above 68C.
1. You won't "lose life" on your cpu at 65c
2. You can run the C2D quite happily at 70c-75c as long as everything is stable
OEM "quiet" boxes run very warm, you would probably think it was going to burn up, but they don't. When Intel says 85c max, they mean it. 75c is nothing to these cpu's.
what about volts? At what voltage will it decrease the life of the chip to under 2 years? I had my cpu at 3.44 but moved it down to 2700 at lower than default voltage b/c I want to make sure the chip doesn't die anytime soon.
