650i vs P35
TechBoy
Ok, let me get straight to the point. I have a Asus P5N-E SLi motherboard with the nvidia 650i chipset which has caused me hell at the start and now is giving me crappy stability. I was looking around and the P35 chipset seems to be good, so I came around to looking at the Gigabyte P35 DS3R, which seems much more stable on oc's than my current board. Would it be a good switch or a bad one or is there some better motherboard out there for less than 150$ that has good stability with a high oc? Reason for me asking is because after a month of running my e6550 at 3.15ghz it locks up and crashes every now and then along with my memory which cant oc any higher than 850mhz with out crashing. Help would be much appreciated.
My advice: Buy a board from Newegg or Frys and if it turns out that it wasnt the P5NE SLI board causing it you can return it.
Now with that outta the way, P35 board is probably the most solid stable overclocking boards to ever come out.
I would make a list of what you need and then look to the proven performers of p35 board makers. Abit IP35-e or pro , DFI DK P35, <---My top 2 for p35 boards
Asus , Gigabyte ( I dont like the bios),
yea I saw the IP35 but wasnt quite sure if it was as stable as the gigabyte.
When it comes to stability Abit owns gigabyte. When you do a bad overclock on a gigabyte it gets all fussy and you have to reset cmos etc etc the usual. Abit, however just requires a nice turn on/off of the power switch. Gigabyte bios also kinda sucks imo compared to abit's.
@ TechBoy
I had a Gigabyte 650SLI-DS4 mobo, after 6-7 months (at stock settings) it started to act strange (boot-problems, lock-up, BSOD).
Now I have an "el cheapo" GA-P35-DS3L which is OK, not so hot NB like the 650i had and it is OC friendly too. :) With the 650i I had too much trouble. :mad:
Whatever mobo you get, the P35 chipset is the right choice for you, I guess... LOL
Hmm, whenever I do a bad overclock, mine turns itself off, reverts back to good cpu/mem speed/votlage settings, and turns itself back on again :)
Gigabyte is a solid board, just saying Abit is a little better p35 overclocker. Btw sup with the vdroop on these typing from a GA EP35 DS3R wow.
