$650 quadcore system refresh question
mikeo
right now i am running an amd x2 4400+ i built a little over 2 years ago but am going to need more ram and power for vmware w/ vista for a security class i'm taking this semester so was planning to upgrade to a q6600 with at least 4gb of ram...
what i plan on using from my old system(s)...
6800gt nvidia pcix
2 tv cards (1 leadtek winfast tv2000 xp and one ati hdtv wonder)
nec oem dvd drive
5 hd's 4sata
thermaltake sonic tower for cpu heatsink w/ mounted 120 fan inside
case has 5 fans on it
an OCZ ModStream OCZ-520 12U 520w powersupply <-- will this be able to handle it or will i have to upgrade the psu too?
what i plan on buying...
core 2 quad q6600: ~287 shipped from mwave
EVGA 122-CK-NF67-A1 680i SLI ATX Intel Motherboard : 177 after rebates on newegg
this cheap memory (4gb worth for now)
for a total of around 646 shipped
are there better or different parts you would get for around the same price or cheaper (i want to be able to oc a decent amount), and is my 520w power supply enough to power all of this? if there are any deals you know coming in the near future i wont really need the system for another month or so.
thanks for the help,
mike
I'd pickup a new PSU, just cuz the modstream is old already, and you don't want it taking out all your new components.
WIth that ram, you can reach 3Ghz before needing to OC the ram.
I wanted an sli board so after i get a dx10 card sometime in the future i could add it to the system and pickup a 3rd hopefully cheap 19" lcd to go along with my current dual displays (a vx2025wm and l90d+). could my 6800gt run in a pcie 1x slot with a dx 10 card or am i thinking right about going with the sli board... the psu is still under its 3 year warrenty so if it is capable of running the system i would probably still use it for another year or so (when i'm likely to get a dx10 card), however if its going to hinder the oc or is not capable of running all the hd's id get a new one.
do i need ddr800 to break 3ghz, was hoping for at least 3.4 with this chip?
DDR2-800 will get you up to 3.6GHz, 667 will only get you to 3GHz (without overclocking RAM). Here's the math you need to keep track of: multi * RAM speed = CPU speed.
Q6600 = 9x multi
DDR2-667 = 333MHz (remember, DDR means DOUBLE data rate)
9*333=3000 MHz
DDR2-800=400Mhz
9*400=3600 MHz
You don't need an SLI board to run multiple graphics cards. You only need it to SLI 2 identical cards together. This means that the 2 cards are linked and running as one, combined more powerful card. Kinda like a dual-processor system. Get a P35 board like the Abit IP35 Pro. You'll be happier.
thanks a lot for the help, didn't know the ram made that much of a difference in these systems (on my x2 would just use a mem divider with ddr400), so is the GA-P35-DS3R currently the best oc board out there right now that isn't sli?
SLI only supports a single monitor. In SLI mode, your other two monitors would be off. SLI is only needed for high resolution 3D rendering on a single monitor. So, if you plan on getting a 1920x1080 LCD or higher, and want to game on it at native resolution, then keep SLI as an option. Otherwise, theres no need for it. A single GTX is still fine for a 1920x1080 (or 1920x1200) LCD screen, and more cost effective than an 8800GTS SLI setup. SLI as an upgrade path isn't worth it unless, again, a large LCD is in the future plans. There should always be a better single card solution, and you could sell your old card to help offset the cost.
In order to run 3 monitors, you'll need 2 graphics cards unless you get a Matrox quad head. So, you could either get a PCI vidcard or another PCI-E 16x vidcard. Unfortunately, 1x and 4x vidcards are still not mainstream yet. So, you could get a board with 2 pci-e 16x slots (usually one is only 4x bandwidth, though) and 2 pci-e 16x cards, or just toss in a pci vidcard with your gaming card.
The DS3R is one of the best boards out right now under $150. If you have a higher budget, the GA-P35-DS3P is another option. The other popular boards are the Abit IP35 Pro and the Asus P5K-E. You can't go wrong with any of those boards.
(CPU Multiplier) x [Base FSB speed] = CPU Clock speed
2 x [Base FSB speed] = RAM speed
4 x [Base FSB speed] = Effective FSB speed
The 2x ram multiplier can be changed to achieve a higher speed ram while keeping the cpu speed lower, for an unlinked config. However, performance reviews have shown that on Intel platforms, running unlinked yeilds little to no performance gains (in other words, its useless to OC just the RAM without OC'ing the CPU). Keeping the default 2x will keep it linked with the CPU, for a 1:1 ratio. So, DDR2-800 is all you need for the Q6600:
Q6600: 9 * 266 = 2.4Ghz, DDR2-533 << STOCK speeds
Q6600: 9 * 333 = 3.0Ghz, DDR2-667 << Nice OC
Q6600: 9 * 400 = 3.6Ghz, DDR2-800 << Great OC, near max (G0 stepping) on good air
We're not worried about the warranty. We're worried whether or not that PSU will take out the rest of your system when/if it dies. With that many hard drives, that PSU may not be able to power your system if you throw in a DX10 card. But for your current system, that PSU should be fine. Though, if it was me, I'd just get a new PSU that has room for future upgrades.
Ordered all the parts this weekend, pretty stoked, i went with:
Asus P5K-E (with wifi)
q6600 with G0 Stepping
2x 2x2gb (8gb total) of g.skill ddr800
I figure ill get a new PSU if i see any fluctuations in voltages when the system is running, or if i ever add / upgrade to a DX10 card...
Hopefully ill get 3.6 out of this chip (I have a thermaltake sonic tower with a 120 fan mounted on it for cooling, and it has worked wonders with my X2 4400+)
Thanks for all the help (didn't know before that i needed DDR800 to OC well)...
Or if it takes out all your new hardware... but good luck! ;) (it most likely won't)
