As I have posted on other threads with other questions, I am going to build a new rig soon, and Im an in the product research stage.
For my mobo I have been strongly considering the MSI P6N SLI Platinum (650 chipset) but have recently started to look at the EVGA mobo with the 680 chipset.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188013
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130081
I think I know the answer to my question but before I drop up to $250ish Id like to double-check myself with you guys.
Myself, with my computing needs, I build my systems to last 2ish years. I try to pick items that have the best out of the box performance since I dont overclock, Im not opposed to overclocking, I have just never sat down to learn how to do it. My priorities with gear are:
1. Out of the box performance
2. Reliability / stability / longevity
From researching these 2 boards it looks to me that they both pretty much have the same out of the box performance but the 680 chipset board just allows more overclocking options? Or is there something more with the EVGA board.
