For windows when I install XP on my next build what are the advantages of using 64 vs 32? I mean besides being able to address the full 4gig...
Has there been any evidence of PPD increases?
64 Bit Vista Ultimate here....no problems, but I have all new hardware. If you have legacy hardware you will probably have trouble with drivers.
Some of my older games don't like Vista 64 either, Kinda necessary to keep a seperate XP partition around for some stuff I have.
The only issue I encountered with Vista 64 and VMware is Driver Signing. Simple solution is to hit F8 prior to boot to disable Driver Signing, but you have to do that every time you reboot. This means you can no longer have unattended reboots.
I would REALLY love a way to turn off Driver Signing for good, but I don't think that is going to happen.
No gain in PPD. The disadvantages outweigh the advantages. You're going to have lots of problems with driver and software compatibility, or so I hear. Being able to address the full 4 gigs IS nice though.
I just upgraded from XP 64 to Vista Ultimate 64. I would agree, if you have XP 32 already, go ahead and install that. I would advise you not to use XP 64 if you are going to use the computer on a daily basis. Microsoft has gotten a little spotty in their support for XP, so you cannot really expect other companies to do much for them.
I too see 64 bit operating systems becoming the way of the future. I have 4 gigs in my system now, and while it doesn't use all of the ram most of the time, on occasion I can open enough to tax things a bit.
End result:
If you have XP 32 and 64 bit, use 32.
If you are buying an OS, go Vista retail (32 and 64) or Vista OEM 64 bit.
I have to disagree with the general consensus.
Q6600 Vista 64 and 2xf@h SMP + Affinity changer is faster than the same with Vista x86.
I get 2 minutes per step better on 64 than on 32 at the same OC.
