Im confused as to the differences between pci and pci X what is the difference between 32bit and 64 bit pci and pci X. 32bit 33mhz is 133mbs for the entire bus. 32bit 66mhz is 266mbs for the entire bus. What are the different pci speeds? Is there a difference between 64bit pci and pci X?
Im basically looking for a break down of the different types of pci and their corresponding speeds and available bandwidth. any info or links will be appreciated.
