samsung.204b
- Aug 6, 2006
besides more memory, what is the 64bit cpu good for?
(cf)Eclipse said:though 64 bit programs are still basically non-existant in the desktop world, and i haven't actually done testing with xp-64 on my 631, everything i see indicates that intel + 64bit os is a somewhat bad idea..
if someone could give the specifics on why, i would be appreciative![]()
i know that, but why?Pabster said:Prescott's EMT64 was dismal.
Conroe's is significantly better. Better than AMD's 64-bit, in fact.
me (From Article) said:Conclusion
As we have expected, nothing serious has happened. CPUs with Intel Core microarchitecture and EM64T technology work normally in 64-bit modes. No dramatic performance drop has been detected in most benchmarks.
Of course, there are a few applications, when Core 2 Duo work slower in their 64-bit versions than it would in their 32-bit ones. Among them are Windows Media Encoder 9 or 7-zip archiving tool, for instance. However, since the other testing participants have also lost some of their performance in these tasks, the problem is most likely to be not in the microarchitecture. EM64T technology of Core 2 Duo processors has a positive effect on the performance in the majority of applications.
At the same time I would like to point out that it looks like Athlon 64 processors ensure higher performance increase when switching to 64-bit work mode. The average performance improvement we have seen from Athlon 64 FX-62 equaled 16%, while Core 2 Extreme X6800 demonstrated only 10% average performance boost. This way, there is a certain difference: AMD K8 turns out 6% mode efficient in 64-bit mode than Intel Core. However, this difference cannot compensate for the 20% performance advantage of the Intel Core 2 Duo over the Athlon 64 X2 working at the same clock speed, which we have pointed out in our previous articles.
Ahh, thanks for the first part explanation for memory addressing. I was wondering why the new 64 bit processors could only support up to 1tb of ram instead of the full 2^64 bits.Torq said:True 64 bit addressing permits a 16 EB (exa-byte, the progression being giga, tera, peta, exa etc.) flat address space, not 128GB. x86-64, whether AMD64 or EMT64, actually uses a 40 bit physical addressing model and a 48 bit virtual address space. That allows for 1 TB of physical RAM and 256 TB of virtual address space. The x86 model is provisioned to for expansion to either a 52 or a 56 bit addressing mode for later support of up to 16 PB.
There are plenty of motherboards that support more than 4GB of memory, and have been for a good while now. Intels D975XBX is certified for 8GB for example, various nForce 4 boards are good for 8-16 GB, and if you want to consider workstation boards there are lots that are good for 32+ GB.
The limit there tends to be a design decision or limit on module size, rather than any specific failing in the addressing models of the hosted CPU architecture. Also you wont often see these boards offered in systems with more than 2GB of RAM, but thats the vendor electing to avoid ill-educated purchasers complaining that their 32 bit operating system is only seeing <3GB of RAM when they purchased 4 or more.
128 bit CPUs are a long way off, though thats the eventual progression. Each successive increase in bit width has taken longer to come, since it takes long to reach the limits of those increases. 4 bit to 8 bit transitioned in one year (1971 1972), for example. Sticking to PC CPUs (to keep things simple) fully 16 bit processors showed up in 1978 (the 8080 had limited 16 bit capability via register combining).
There were various refinements to the pure 16 bit model (protected memory, 24 bit addressing) over the next few years (think 80286), and it was 1985 when the first fully 32 bit PC CPU launched that being the 80386.
Ten years after the 386 launched we got the first mainstream 32 bit PC operating system (Windows 95, 9 years if you include NT Workstation), and it was another 8 years before the first 64 bit x86 compatible CPU showed up (AMDs Athlon and Opteron 64s in 2003).
So 18 years of 32 bit CPU availability before 64 bit PC processors showed up. During that time lots of changes occurred, both in terms of instruction set additions (on boarding of the FPU, addition of MMX, SSE, 3DNow! etc) and architecture. So that likely puts 128 bit CPUs a couple of decades out, and definitely not something to worry about.
my research thesis would likely benefit from > 4GB of RAM.samsung.204b said:you guys saying 64bit is more complex? why would someone use more than 4gb of ram, graphics/lan parties/games? in the time of 16bit, what did 32bit gave us? what's the future?
I am running this DEP mode on all my machines and I remember only a single incident, where I needed to exempt an application.torq said:You can choose the other option ("Turn on DEP for all programs and services except those I select") and that will enable DEP for everything. Note that some applications may not operate correctly in this mode, and in those cases you can add the offending applications to an exclusion list by using the "Add" button on this same configuration page.
