Which waterblock can i get that will fit the 3200+ Mobile's (with the 1.4v)? I've noticed alot of heatsink's will not work with it, i already have a WCing kit for my current system trying to get just upgrade it with my mobo/proc I'm going to get.
From what I understand, the 3200+ Mobile's don't have heat spreaders installed. If they in fact don't have them a normal A64 water block might not clear the socket cam box just like the Athlon XP CPUs. If thats the case, you would have to have a stepped water block like those used on the XP and uas a retention system from a A64 water block. It really wouldn't be all that hard to do though, just get a Swiftech 6002A CPU block and order the A64 bracket extra. Easy as that.
