64 bit?
I am in the process of building a new pc (to be finalized when Vista comes out). I am not sure of all the details about going to a 64 bit OS. Can someone please explain to me the benefits as well as the requirements to do this?
Is my current projected setup OK to do this with: ASUS P5N32-E SLI, E6600, 2GB RAM (not sure what kind yet), EVGA 8800 GTS, Raptor 1500 HD, Windows Vista Ultimate (or Home Premium).
You will be fine to run a 64-bit OS with that setup. Basically 64-bit allows you to have a TON more memory and also allows a larger data path for processing. In my comparison burning a CD, for example, took significantly less time in converting the mp3s to wavs for burning. There are few applications that utilize it and even fewer games that do. I do know that anything from the Half Life 2 series does use 64-bit. Nero also uses 64-bit I believe. With windows XP it was very hard to find drivers. The HP beta drivers were the worst(for their printers). When I loaded up RC1 64-bit of Vista there was a driver that came with it and it worked flawlessly. The driver support with Vista is there MUCH more than what is there now for XP. I personally plan on going to 64-bit vista home premium.
Using 64bit is not an issue running legacy games?
I play old school EQ1. ( I'm in a top 10 serverwide raiding guild, and we are still going fairly strong, so im not about to let go of the character Ive speant 2 years developing and playing )
Do legacy games, etc..run fine in the 64bit environment?
Maybe I will consider that as well, if they do...
but wait... my new rig is 6700 based Maingear F131
these aren't 64 bit like AMD's, so how do the core duo's run 64 bit os?
The new Intels have 64-bit instructions. I'll look into legacy games. I dont play them myself.
Many legacy games won't run on the 64bit versions of Windows. Mainly the problem stems from those legacy games having 16bit installers or other issues along those lines. The applications should all work if they are 32bit. Virtually everything that works on 32bit Windows will work on 64bit Windows provided we aren't talking about drivers.
As for 64bit games here are the ones I know of:
UT2004 (w/patch, runs a bit smoother overall, that's it.)
Far Cry (enabled w/patch, runs the same, but has better textures and additional content in some maps/areas)
Half Life 2 (w/patch, never tried so I can't comment on it.)
Chronicles of Riddick (Game includes 64bit and 32bit binaries, but I am unsure what differences if any there are between the two. Nor do I know if anyone has actually run the 64bit version.)
That's about all I can think of.
