64-Bit Compatibility Required for Windows 7 Sticker
Terry Olaes
I Used to be the [H] News Guy
Microsoft has started issuing “Compatible with Windows 7” stickers to system builders. According to PC Pro, MS is now requiring that a stickered PC be able to run all versions of W7, including 64-bit. After the “Vista Capable” debacle, we can only hope that MS has learned a lesson and actually certifies a fully-featured software configuration.
Microsoft also claims that "products that receive the logo are checked for common issues to minimise the number of crashes, hangs, and reboots experienced by the user," although it gives no further details of what such tests involve.
So this means that even single core P4s will techinically be able to get the Windows 7 Capable sticker...
Hrrrmmm... sounds a lot like the Vista Capable sticker.
Min requirements for the Windows 7 sticker should be a 2Ghz C2D or AMD Athlon 64 x2 2.5Ghz with 4GB RAM and a video card that can handle all of the visual features of Windows 7 easily.
Some of the NForce athlon64 motherboards don't have vista drivers (and presumably will never have win7 drivers). Of course, if you have DDR(1) you might as well toss the whole thing as it would be cheaper to buy a modern system than to shove 4M or more of DDR into it (God help the poor souls with P4s and rambus).
A Microsoft OS upgrade has always been done best by buying a new machine. This is to MS's benefit, as it's easier to stomp out piracy at the OEM level.
Of course what MS doesn't seem to require is some sort of test suite run against a 64 bit win7 image prepared for each machine (don't tell me this isn't trivial, if they can't do this easily it can't possibly be considered compatible for people who go by idiot stickers).
They really need to be careful doing that system again, imo that vista capable crap was one of the reasons vista got a bad rap. They claimed so many systems were vista capable when they barely met the system requirements, then you had thousands of people claiming vista was slow and unresponsive, when in reality their machines were out of date. The visual improvements and system requirements were much higher than XP and people weren't ready. Obviously hardware has evolved since vista and should be able to handle 7 a little better than when vista was launched. MS should be careful on what they slap a win 7 capable sticker on before they shoot themselves in the foot again.
http://windowsteamblog.com/blogs/windows7/archive/2009/09/29/the-windows-7-logo-program.aspx
That is probably where PC Pro is getting it's info, which if so, they are actually mistaken on what he meant and he later clarified it.
Update: To be clear, this program “Compatible with Windows 7” is intended for applications and devices you purchase after you get a computer, which is why supporting 64-bit Windows 7 is a logo requirement. As part of the Windows 7 Logo Program for computers, we have separate requirements that ensure PC’s will have a great Windows 7 experience out of the box and can upgrade to any edition of Windows 7. We’ll have an update on PC’s and what you’ll see on shelves in the coming weeks.We already have tons of great new PC’s in the pipeline running 32-bit and 64-bit in all types of form factors including small notebook PC’s (netbooks), tablets, desktops and all-in-ones)
You don't have to worry about old P4s and DDR1 systems being certifiable ad the logo requirements are actually always a moving target. They require certified specific drivers and capabilities and it changes around every quarter or so, which is why they usually don't make a lot of the standards public.
... Min requirements for the Windows 7 sticker should be a 2Ghz C2D or AMD Athlon 64 x2 2.5Ghz with 4GB RAM and a video card that can handle all of the visual features of Windows 7 easily.
Oh reallly?
I have an ASUS eee900 that's quite happily running Win 7 RTM better than it was running the original XP install.
A CELERON 900 Mhz with 2GB ram and a 16GB SSD, is very capable of running WIN 7.
Oh reallly?
+1
My Acer Aspire One runs it beautifully (Atom 1.6ghs, 1.5gb ram, 120 gb hdd). All drives worked out of the box as well.
This forum needs a system to down-rank people like you, for spreading misinformation; your statement could not be more inaccurate. As is pretty well known at this point, Win 7 is nearly as efficient as XP was, and does not need nearly this much CPU power or RAM. I've heard about people running it on old P3 laptops with 512MB of ram, and saying it breathed new life into systems that were once thought to be trash.
I recently put it on a family-friends computer that had a P4 2.4 (single core no HT) and 2GB of RAM. The system was extremely responsive and a great experience to use for any task I threw at it. memory usage was at most around 600MB used, even with several things open.
With that said, I am 100% behind Microsofts requirement for a 64-bit CPU. This should drive Intel, AMD and VIA to cease the production of CPUs that don't support x86-64. This benefits both the consumers and Microsoft (who no longer has to develop a 32-bit OS).
I hope this is a sign that Windows 8 will be 64-bit only. IMO Win7 should have been. The cut-off needs to be made. just like 16-bit.
They stated that 7 would be the last 32-bit version a while ago. They already made the move with WS2008 R2. Likely the only reason they didn't do it with 7 was because Intel still made 32-bit only processors up until like a year and a half ago which obviously would have upset someone once it came out.
Hrmm.. old P3 systems with 512MB of RAM.... Sounds like they just mainly needed to wipe the drive and re-install anyway.
I am NOT talking about OLD computers having a Windows 7 sticker on them... I am talking about NEW computers coming with the Windows 7 sticker on them.
Sure, the OS may run fine on older hardware when first installed.. but wait until a few things are installed and running in the background.. like anti-malware and anti-virus, printer monitors, etc.
You will see an older system come to a screetching halt compared to one with newer hardware.
Sure a lot of us here may know how to tweak our systems and keep them running smooth, but at the same time, the Windows 7 Capable thing will be mostly for the standard, non-techie user who has no clue on how to do this. All they know is that they are not happy when their system starts being really sluggish when it was advertised as being "Capable of running Windows 7".
The sad part is there will still be issues because people are stupid and don't bother to read.
Mobile atoms are still 32bit only (only the desktop ones are x64). I'm not sure if they're planning to add x64 to mobile pineview or not. If MS is dropping win32 from W8 they really ought to to avoid a PR bomb in 2011/2012; but on the mobile front intels main objective seems to be keeping the transistor count as low as possible to invade arm territory.
Win7 (unlike Vista) runs fine on my 2.1 GHz C2D laptop with 2GB of RAM and Intel X4500HD graphics. This includes Aero. I doubt a slower CPU would cause any problems as long as it's a dual core. My system rarely hits more than 50% CPU usage running normal apps and browsing the net.
Now if you want to play 3D games, that's another story. But it's up to the game publishers to indicate sensible minimum requirements.
Whaaa? Part of the reason Win 7 is so great is that it DOES NOT require as high specs as Vista to run well. Case in point: I have Windows 7 Pro on both a Dell Latitude D420 with 1.5gb RAM and Core Duo 1.2ghz, and Lenovo Ideapad S10 with Atom 1.6ghz and 2gb RAM..... and it runs better than XP on both machines.
The sticker in question (Windows 7 Compatible) is not intended for use on a computer -- it's intended for peripherals and add-ons. Mice, keyboards, graphics cards, network cards, routers, etc. etc.
honestly, you could say that about any os, dump background programs into winxp and you will see the same slowdown. The difference is that 7 is more efficient at handling background crap.
i have 7 on every computer in my house, including my "mess around" systems of varying generations. All of them run windows 7 just fine, and I have some of them set in what i would call an "average user" scenario (so i can know what to do when these people have issues). all remain responsive after adding various basic programs... ok well the p3 with pc133 not so much but i can honestly say i didn't expect much out of it. my pentium mobile and single core turion (the s754 series) laptops run better than they did on xp. hell i was even impressed at how nice my little 478 box ran on win 7.
the thing here is if you want to argue about that sticker thats fine, i agree that a really old system just barely meeting min requirements is not going to get a full experience... however they would also not have a sticker saying its capable of running it. Those come with new systems, and damn near everything out now should be able to run it just fine...unless you are installing it on a phone or something :p...and even then phones these days.....:D
seriously though, my gf works at walmart, if i get bored waiting to pick her up i'll browse the shit section of ghetto pc's they have...even their garbage ones could handle win 7 without losing responsiveness ala early oem vista.
Why do we need/must have a 64bit OS?
That is a little weird... because they sell both 32 bit and 64 bit versions of Win7. So what's the big deal about adding a win 7 64 bit capable sticker??
Comparing early OEM Vista is not even really valid at this point.... it should be compared to Vista SP2.. which is a whole lot better than original Vista.
True Windows 7 is still a bit better than Vista with SP2, but MS has come a long way since Vista was originally released.
The only systems my suggested required specs for the stickers would eliminate at even WalMart are single cores and a few that didn't have 4GB of RAM. RAM is so cheap now days that there is absolutely no excuse that any PC should be built with less than 4GB (note.. I didn't say netbook or notebook).
If they wanted to put Windows 7 stickers on those, then I would want them to be required to have a disclaimer that said that it wouldn't run it near as fast as a higher end system....
Most general users would just look for the sticker and price.
If it was my software that was being "certified" to run on a system, I would make sure that the user would be able to get a very good experience out of the system it is "certified" for.
They should have different tiers of the stickers.... Like bronze, silver, gold, and platinum.
Every store that sells PCs with the stickers, should have multiple copies of a guide that shows what the requirements for each sticker are, and what the customer should be able to expect out of a PC with those requirements.
They pretty much did the same thing with Vista. Its to ensure that the user experience on the 64-bit side is as good as it is with 32-bit. There are a lot of users running 64-bit Windows, its no longer a niche market for us enthusiasts with 4+ GB of RAM.
I would assume that since Server 2008 R2 is 64-bit only they'll be doing the same thing with Windows 8.
Funny you asking that question, since it says you're running XP 64 bit. :eek: :p
I don't think it's a must. However if you want to address more than 4GB of RAM, then you need a 64 bit OS. Also, microsoft, and by extension most manufacturers have stopped supporting XP with the latest drivers. So if you want your drivers up to date and such you need Win 7 64 bit. You could always just run Win 7 32 bit, but you'd be missing out on the extended RAM support and extra stability of 64 bit.
I remember when I was an early adopter of 64 bit windows for AMD 64. It was a NIGHTMARE because of the lack of driver support and lack of 64 bit programs. That is no longer the case now. There are plenty of 64 bit drivers and 64 bit versions of programs to run on Win64 or you can make them run in the improved compatibility mode. Antivirus 64 bit, 64 bit drivers for video cards, etc. etc.
Those were the days :D
My first 64 bit capable PC had an Athlon64 3000+ and 1GB of RAM
It's pretty meaningless actually. With the exception of Nettops and Netbooks, there pretty much are no PC's shipping theses days without a 64bit processor, 2 gigs of ram, and integrated video that can handle Aero. Even in the $600 laptop range 64bit dual cores @ or above 1.5Ghz, with 2 gigs of ram are the norm now.
It's pretty meaningless actually. With the exception of Nettops and Netbooks, there pretty much are no PC's shipping theses days without a 64bit processor, 2 gigs of ram, and integrated video that can handle Aero. Even in the $600 laptop range 64bit dual cores @ or above 1.5Ghz, with 2 gigs of ram are the norm now. edit: Almost all hardware mfgs have 64bit drivers as well now.
..edited for overly quick submit click.
This was without a doubt a major milestone. The road to 64 bit has been slow and tedious but I have no gripes against it. Market saturation of 64 bit CPU's is very high and you'll be hard pressed to go into a retailer that sells desktops without 64 bit capable CPU's inside them (including notebooks, etc). It makes me remember the days when the Athlon64 was launched, and later followed by the addition of 64 bit capable P4's and the introduction of XP Pro 64bit.
My Canadian Computer supplier, Supercom has only offered XP Business or Vista 64 Home premiun/Business w/W7 upgrade for the last couple of months on its entire prebuilt line. 64 bit world is coming.
Cheers!
Ahem my machine runs Win7 superbly, for what I need my machine for, I ain't spending another dime yet, other then the new vid card from ati. Sorry but DDR1 is still kicking ass for me. No problem with drivers in Vista either.
This has little or nothing to do with windows 7 being able to run on existing systems, and everything to do with getting manufactures to support 64bit moving forward.
We don't order systems with less than 4GB of ram anymore and many of our developers want more so they can run several Virtual Machines at once. To do this efficiently you need the 64bit version of the OS. There are so many system components and peripherals out there still shipping without 64bit drivers, it is very frustrating. This is a great move by Microsoft.
I think that a lot of people here are missing the point. This sticker program is not for computers, it's for software and peripherals. By getting a product with one of these stickers on it, you will know that the included driver disk, or the manufacturer's website will have 64bit drivers available. Keep in mind that a Windows 7machine will be the first 63bit machine that MOST consumers will buy. As a result, its the first time that they need to keep 64bit-ness in mind when downloading driver etc.
It's more an awareness campaign than anything else.
I agree MS can't afford to bend over for the OEM manufacturers again. They better not just have real min reqs, but conservative reqs for the Win 7 certified certificates. Heck all those machines in most B&Ms and online stores still come with so much crapware you need a mid range machine just to run one program without it dragging.
I ran the beta and now the RTM on a laptop with a mobile P4 1.8 with 2GB of ram, and an ATI x600. No, I have not tried any games, but it does all the work related tasks as good as XP ever did, including the occasional work in Photoshop or Illustrator. I mostly do patch up coding to websites while traveling on it. It feels really fast though, and the hibernation works like a dream. I can go days without powering it down or charging it with light use. That is really handy for traveling and popping it open for 30 seconds to check something for a phone call.
Before I had XP and one or two flavors of linux on it. I used xp maybe 30% of the time. When I went to windows 7 beta times about flip flopped. When I moved to the RTM I wiped the drive and just loaded Win 7. Mostly because it did need the space, but I just tossed a Virtualbox of Ubuntu on it and it meets my needs. I do still have native Linux on some home machines and run Linux servers. Lets see if marketing can screw it up for Win 7.
So which systems now days don't have 64bit CPUs?
Many systems. When I worked in IT, there were many systems with 32-bit CPUs. Businesses and the government adjust and change their systems much more slowly than others.
Intel mobile processors were 32-bit only until the Core 2 processor came out, and that was only starting at Merom, some Pentium Dual Cores does not and some of the later Celerons do not as well. As for AMD, some Sempron's do not.
New computers that will be shipping with Win 7 installed, are pretty much all going to be 64 bit any way, with the exception of net tops and net books. Old PC's don't get a sticker, so their is no real point in bringing them up in a thread about a sticker. :p
