620hx + xfired 4890's
Angst!
I've been lurking here for years, but I am about to pull the trigger on a build, and now I need some direct advice.
I am looking at picking up the 620hx and 2x xfx 4890's, with an e8400.
I will have one HD, and one optical drive.
My goal is to oc the cpu to at least 4.0ghz using a true.
And to oc both gpu's as high as possible on a ud3p.
Will the 620hx handle all of this? My gut thinks that it will be near load, and that I should just get a 750tx and forget about going modular. Anyone have a similar setup, perhaps using 4870's that can provide insight?
Thanks much.
The HX620 is enough, but you would be past the peak efficiency range. It would be a good idea to purchase a higher-capacity unit; I would suggest something in the 700-900W range. The TX750 as you mentioned would be a good choice, as would be the TX850 or the PC Power & Cooling Silencer 750 for more budget-oriented PSUs. For something modular but still reasonably-priced, the Antec Truepower New series of PSUs is excellent quality, modular, and also not overly expensive (although they obviously do still command a premium over non-modular units).
620hx has been shown to output up to 750w without an issue via various tests and my rig doesn't get close to 600w according to my ups.
Just because it can output more than it's rated for doesn't mean you should exceed the rating.
Yeah like people said a single 4890 is taking around 280w under load, i think it would be too much for the psu, you may eventually need a new unit. You are putting too much stress and it'll eventually die.
A single 4890 will not use anywhere near 280W under any sort of conditions.
A highly OC'ed one will.
EDIT: Seems as I was highly mistaken. I thought it equaled the TDP of higher end Nvidia cards.
A single 4890 is lucky to be able to draw 300W => 75W x2 from 6 pin connectors, 150W delivered from the PCIe 2.0 slot is still not highly common.
Radeon 4890 TDP is 190W IIRC, it shouldn't come close to 280W...
And at the OP, while a 620HX can handle it, you'd be better served by getting a 700-800W unit that will run closer to the peak of it's efficiency curve.
Single 4980 idles at 190W, AFAIK. The 620HX would be cutting it close, as other mentioned, so it may be wise to either run a single-card setup or go with a quality 750-800W power supply.
The 620HX will handle all of that with ease, with all the overclocking and volt mods your heart desires. If you decide to add an i7 and overclock the hell out of that, then you'll probably need a new PSU. Until then, while overclocked you probably won't even be pushing 450W at peak load.
620HX only has 2 PCIE plugs. 2 4890s need 4 PCIEx6 plugs. You can go molex, but that kind of defeats the cable management bonuses of a modular PSU.
Corsair will provide cables with a 6-pin and an 8-pin connector each upon request. In fact, I believe the newer HX520 and HX620 already come with them.
The older ones shipped with 6pins; New ones just have 6+2pins. Don't think they do 2 PCIE headers per cable like some of the Silverstones do (e.g. ST85F).
They do. I'm not sure if they actually ship them with the PSUs, but I know for sure that they do offer them.
Thanks for the advice fellas, I decided to go with an i7 build, I like the option of having both xfire and SLI immediately available. I just ordered the TX850 to power it.
Yeah i was a little off on my numbers was reading something else :p
