6200 on its way.
CamaroRacing
I ordered a refurbished Gigabyte GeForce 6200 this morning from the 'Egg. Anyone had any luck overclocking these? I read one theard where they recommended using Rivatuner. Whats a good program to use to test the stability of the card after overclocking?
I play a little Doom 3. If it is going to artifact, freeze, or lockup, it will do it quick in D3. I also use RTHDRIBL to heat up the card, and check for artifacts.
If you have any more money get some memory. 256mb doesn't cut it at all.
