Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am looking to a get a computer from dell with the integrated 6150. The only "intense" gaming I will be doing on it is Counter Strike 1.6. Will this integrated 6150 give me 100fps?
It should give you plenty of fps. My 6100 with a sempron 3000 is powerful enough to play cs:s @1280*1024 , all settings low. cs 1.6 is much less intensive so you should be fine.
Not sure why youd need 100fps, anyways my friend has a 6200oc . athlon 3200, and 512, he gets 80fps average in source with all settings low 1280x1024, also be aware that the 6150 borrows memory from your system so make sure youve got system ram to spare
