planetary said:My problem is, I can't get the "Apply these settings at startup" to stick. I'll set my clock to 423/1.15 on my 6800 GT, then check the box, and then click ok. But every time I boot up, the settings are back to default. What gives?
planetary said:I'm using whatever this one is....I think it's (1).
planetary said:Is 2 better? If so, I'll try that. To use Coolbits2, must you undo Coolbits1?
planetary said:Are you saying I'm dumb?![]()
tornadotsunamilife said:please be my guest and try but if you screw something up don't blame me
Unit-0 said:Coolbits 2 eats ass.
It REMOVES a ton of options and only putting in a fan control function.
