60mm Fan Comparison
roastpuff
Which 60mm fans are the best?
So far, the local suppliers have these:
SILENX 16DBA SILENT CASE FAN 60MM 2400RPM 18CFM 3/4PIN $15CAD
SUNON 60MM CHASSIS FAN $7CAD
SUNON VAPO BEARING BRUSHLESS 60MM CHASSIS FAN $7 CAD
ANTEC 60MM CASE FAN 2600 RPM 30DBA 34CFM $8 CAD
AHANIX SILENX 60MM FAN 2 PIN $16CAD
What I am planning to do is mount a pair in two drivebays, in an ANTEC LANboy case, connected to a HardCano 13. I will be using some sort of grill/wire mesh to cover them, for safety and looks. I just want to know whether they can fit, how they sound/perform etc. I will also be adding a bubble light tube on top to cover the gap left between the top of the fans and the top of the drive bay.
Thanks in advance for the help!
Edit: Mounting would probably be with screws or silencers onto a thin piece of wood.... not sure yet. Maybe scrap metal plate?
