60mm Copper heatsink needed
synaps3
I need a copper heatsink that is at least 50mm x 50mm, but at largest 60mm x 60mm (60mm x 60mm is best). It also HAS to be copper. Aluminum would not work, due to corrosion.
Anyone know where I could get one for cheap? I don't need anything fancy, almost anything will work. I can probably even cut down a longer heatsink, as long as it is copper and the width works...
