6073
W.Feather
[H]ard DCOTM x4 & [H]DCOTY x1
Just curious guys, what are you getting with this unit ? I lost all my previous data(forgot to bring it with the new install), and the time's/PPD i am getting seem off.
With a 1090T at 4.0 Ghz CPU, 2.8 GHz NB, 1600 MHz RAM speed, got a 9695 PPD, with TPF of 4:30....over 4 frames, figured it has a good idea of the times....just wondering what others are getting to know if i have a)Bad OC, b) Bad unit, c)Am expecting more on a slow WU....
Closest I have is 6072 and 6074, anything from 9.3k to 10.8k. Thats on a 1090T @3.4, running DDR2 800 and a GTX 460
so possibly something wrong for me then :D If possibly similar units at 600 mhz less are getting better.....just trying a voltage drop overall to see today...
Possibly - it may well be that some units don't scale as well as others, let it run through and let us know what you get on the HFM benchmark
i will let it continue to run, to be safe i quickly rebooted and put my CPU voltage back where it was (all the testing i did was a quick 5 pass, high, test of IBT), letting it go.....really wish i could get my CPU to 4.2, i'm volts limited i know that (maxing at 36c folding atm....), just dont want to pump 1.55v in (which requires me putting ~1.6v in the BIOS....vdroop is insane on this board....at 1.5375v its barely at 1.49v actual)
pretty sure it was volts, another 5 steps in and i'm up 1k PPD....
Nice - i probably have the most crippled 1090T setup here so for me to be beating yours at 4.0 indicates a problem that now looks solved:cool:
well the unit could be unrelated to the others, Tobit had data for a 6074, so not sure still will know when i get off work tonight....up to 11.3k, 4:02 TPF.....so improving gotta give it time to level out, atm i have it set to average over the length of the unit
edit: swapped to last 3 frames, and its at 11;5k, 3:59
6073 i got 5019.7 PPD average which is within the norm for me on those WU's when i have my GPU clients off which for that WU i did.
