Upgrading from a Phenom II x4 955.
Gaming, Web, Code.
$600, Yes tax and shipping included. I have Amazon Prime. Willing to drive to Microcenter.
US. Temecula, CA.
CPU, MOBO, Case, CPU Cooler, SSD. More RAM?
PSU - Corsair 550VX
RAM - 6GB Tri Channel G Skill http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
HD - 500GB Samsung F3
GPU - ASUS 6870
Sound - ASUS XONAR DG
DVD Burner
I'm not positive but I think the Hyper 212 PLUS would be compatible with a new board, I could keep that. Was considering getting a h60 though?
6) Will you be overclocking?
Yes.
27", 1920x1080
2 Weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
mATX. USB 3, SATA 6, RAID.
Yes, 8 64.
http://pcpartpicker.com/p/2QuEZ
I think my 6870 will hold up for a bit longer. Didn't put a motherboard in because I haven't done the research. Appreciate the help!
Gaming, Web, Code.
US. Temecula, CA.
PSU - Corsair 550VX
GPU - ASUS 6870
DVD Burner
Yes.
27", 1920x1080
2 Weeks.
Yes, 8 64.
