$600 mATX AM2 build
GJSNeptune
Building an Athlon X2 rig for my parents. My main trouble is picking the motherboard. Reviews seem lackluster, and people seem to have the same problems. So far the AN-M2 seems like the best bet.
Is it pretty safe to get XP Pro 64-bit now? I'm worried a lot of stuff won't work right. My parents aren't the greatest with computers, and mom needs everything to go smoothly or she overreacts and starts blaming me or my dad.
Dad's getting into Photoshop and will be working with RAW images he took in Italy with his Olympus SP-550UZ. The CPU is still up in the air. He may choose to spend more for a faster one. I might even dabble in overclocking.
Any suggestions other than the AN-M2? I would also consider going with a more solid, higher-rated board with less powerful video and getting a low-end video card.
ABIT AN-M2
ASUS M2A-VM
BIOSTAR TA690G
I have the Abit AN-M2 and love it. It's in my Windows Home Server box so i'm not overclocking my 4200, but i've heard 300+FSB is attainable on this board.
Looks like a nice setup to me. The abit boards are the best for matx overclocking boards and pretty feature heavy. The biostar Tforce boards are very nice as well. If you dont plan on overclocking, Id pick what board has the features they need and forget about buying a graphic card.
As for Windows XP 64, Im not a big fan. I used it for a few months when it came out and it was plagued with issues. I tried it on a recent build and used it again back in May and June. It has came ALONG way but it still had minor quirks that annoyed me. Id look up the programs they use to make sure they are problem free and hope they dont run into issues.
You can save a bit of money by getting that S-flex fan from this site:
http://www.jab-tech.com/Scythe-S-Flex-Fan-SFF21D-pr-3255.html
Don't go with XP64. Some older people have trouble with 32bit XP so 64bit Xp may not be a good idea. I doubt your parents really need that slight bit of performance increase or even the ability to use 4GB of RAM. So 32bit XP should be fine.
If you're gonna spend that much on a 160GB drive, you might as well spend an additional $5 for a 250GB hard drive that also comes with a 5 year warranty like that WD you chose:
Seagate Barracuda 7200.10 250GB 7200RPM SATA 3.0Gb/s Hard Drive - $65
The YS series WD drive is a server class hard drive, and comes with a 5 year warranty. Very nice sturdy and fast drive for a 160gb,and almost silent.
Yeah, I bought one for my rig awhile ago. Thought I'd get my dad the same, but the Seagate's a pretty good deal as well. See what he thinks.
