$600 build - need opinions
Swishbish33
Gaming and Photoshop, but also general use
$600 total. No higher.
3) Where do you live?
San Diego, Calif.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, Mobo, RAM, Case, PSU, Hard drive, Video card
19" LCD, 1280x1024, DVD-RW drive
6) Will you be overclocking?
Probably not
19" LCD, 1280x1024
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing out of the ordinary.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, Win 7 Pro 64-bit
I'm having trouble deciding on the CPU and Video Card the most.
CPU: Athlon II X2 240/245/250? Athlon II X3 425/435? Phenom II X2 550 Black? Phenom II X3 720?
Vid Card: 9800 GT? 250 GTS? 4770? 5750? 4830?
Thanks guys!
Damn, that Samsung F3 500GB is STILL out of stock?!? :(
g's build with shiro's gpu switch is good. If the F3 is in stock by the time you place your order, go for it instead of the 'cuda.
