$600 Build Help
Sankervick
Gaming (fps,sand box,indie,strategy)and web browsing
$600 for build (except for mouse and keyboard) tax and shipping included.
California in the Bay Area
CPU,RAM,case,video card, motherboard,optical drive, PSU
Not reusing anything.
6) Will you be overclocking?
No.
1440p and 13 inches long.
1 week to 2 months max.
9) What features do you need in a motherboard? RAID? Crossfire or SLI support? eSATA? Onboard video (as a backup or main GPU)? etc.
VGA,HDMI
No,it won't be included in the $600 cost.
Thanks in advance.
Which specific games do you want to play?
What's the brand and model of the monitor?
Were you planning to buy from NewEgg or Amazon?
I
I want to play BF1,COD,Crusader Kings 2,OOTP 18 and Cuphead.
The monitor model is HP w196b.
I want to input the build into Pc part picker and get each part from the cheapest location.
Made a couple of changes but the extra $40 is well worth it:
https://pcpartpicker.com/list/fsrbnn
Swapped out that dual core I3-7100 for a true quad core i3-8100 which also required switching the motherboard.
Increased your RAM speed from 2133 to 2666 while actually saving you a few $'s.
Also swapped out that Corsair unit for a 620W Seasonic (better unit and cheaper).
That's probably the best build you can afford right now. You can always upgrade ram in a couple years when prices finally come down, but until then 8GB will get you by.
The next step down in price would be a Kaby Lake Pentium (4 threads, but only two cores), but that has an uncertain future.
https://pcpartpicker.com/list/gnRmd6
Four real cores is definitely worth the premium. But I can understand if you can't jump up to $650.
Thanks! Should I build asap or wait a month or so?
Also, does anyone know where to get a old broken computer to take apart and put together? I want to ask him if I can do that so he's not afraid that I'll break a computer part putting the 700 dollar one together.
So for everything but CPU and mobo buy now, and wait for ryzen 2200 specs to come out? What's the MSRP?
Don't wait for ryzen 2200, you don't need a powerful integrated GPU. The CPU is 3.5 GHz base with only four core, which is exactly the same as the 1300x.
And you can plainly see here the 1300x getting it's ass handed to it by the Core i3 DDR 2400 in games :
https://www.techspot.com/review/1499-intel-core-i3-8100-i3-8350K/page3.html
They both have the same number of cores and threads, and he exact same base clock. The IPC advantage of Intel wins out in the majority of games.
You'd have to step-up to 1500x to get something that outperforms with the i3 8100, and that's $20 more expensive (I wouldn't run an 8-thread processor on a $50 board).
https://pcpartpicker.com/list/wqrKPs
Your call which one you pick up. One is slightly faster than the other, but $20 more expensive. The 1500x will be significantly faster in video encoding though.
It would be a cold day before I spent $400 on a 1050 TI. A non TI, or an RX460/560 can be had for about half of that with the right deal and your gaming experience would be 90% of the 1050 TI. Buying a 1050 TI at a 1070 price point is not money well spent gaming.
