60 Fps in cs?
if it's CS:Source you're talking about, you'll have to turn Vsync off and set your max fps to 100 (Higher won't show higher, CS:S is locked to not go any higher for some dumb reason)
if it's CS 1.6, same options apply, but not the maximum fps thing. You can set that to 500 to see what it can really do.
GL
Well i i dont know surely how to turn of vsync. Is it the opengl / d3d thing where it says default off???? Im not too sure
If you are playing Counter strike, counterstrike condition zero, turn of the v-sync. And type fps_max 100 to get 100 fps if your video card support it.
I am not too familiar with an ati card but it should be like this. Right click the desktop. go to property. go to setting. advance option. Your video card. Find the place that said v-sync (vertical Synchronization), For me it is in the performance and quality tab since i'm using an Nvida card. Uncheck the box or what ever.
Type "developer 1" in the console for old CS to get over 100 fps once you've raised the max_fps and modem_fps over 100.
