6 Pin PCI-Express Cable
jotajota
Hi,
I just installed my new Antec Neo 480 watt PSU, and the instructions say that there is a dedicated 6 pin PCI-e graphics card cable. I don't see any connector for this cable on my graphics card (6600GT) and never have had to use any power but the PCI-e's slot power to power this card. I was just wondering what graphics cards this 6 Pin connector is used for and is my graphics card suppose to be hooked up to it?
Thanks!
6600GT doesn't use a 6 pin cable. the pci-e slot provides enough power alone (up to 75W).
The connector is probably designed for motherboards with a matching connector. I'm guessing on that though.
what they said...6600 does not use that cable, i myself was pretty suprised....but 6800 and x800 use that cable...so keep it :)
I had a 6600GT PCI-Express and it didn't have a power connector on it at all. My 6800GT PCI-Express on the other hand does have the 6 pin molex connector.
Does the X600 need one?
There is a Sapphire one I'm looking at, and unfortunatley there is no connector for one. So I'm gonna go out on a limb, and say that it isn't needed.
Maybe you have to solder one on. Wouldn't a DIY kit for a video card be great? You too can speed bin the memory and asemble the parts on the PCB!
Nah, the "weakest" (only using the term relatively, guys) ATI card that needs this cable is the x800 pro. The x800 has a spot where one would go, but they use the same PCB for most of the x800 series it seems.
Not all X800's do. Take the XL for instance, it doesnt use one either.
