Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
So my gtx 970 has 2x 6 pin power connectors and my power supply cables give 6+2 pin connectors. I should be able to just snip off the extra dangling 2 pins, right?
Sure you can, but why would you want to? If you're concerned with looks, buy a 6 pin custom extension. Like others have said, you might need those 2 extra pins one day.
If you really want to, just make sure you cut them cleanly and try not to leave bare wire exposed where it might short something.
Seriously - don't be snipping wires with your power supply. You're going to have a bad time. If it really puts a black fly in your chardonnay then just wrap it down with some fancy electrical tape.
At the basic level the 'hurt' is the lost functionality for a trivial thing like "it looks tacky". The more theory 'hurt' being having two clipped wires floating around computer case. Again - if I always caution when mucking around with things like power supplies (ground wires or not). In the end it's your rig so go nuts if you feel the urge. I would like to see your before/after pictures to see how much "tacky" was resolved.
If I'm not mistaken, they gave a few sets of the exact same pci-e cable. I would clip the excess 2 pin adapter as close to the base of the rest as possible. I can put liquid electrical tape on the exposed part if need be.
