5970 Question
GetFunk01
Do i need to install the crossfire profiles with just one 5970? Or since its only one card, i dont needd them?
I've heard you should, but either way it wouldn't hurt. If it doesn't use them it doesn't use them. But if it does, then you have them installed.
