ok 2x 5970 crossfire
This was the only way i could get them to fit onto this mobo... the last PCIE was not enough room to fit the 5970 ( power supply )
My question is this, does the fan hole pull air in or does it just create the suck from the back of the card? The two seem pretty close and the top card is 8C higher then the bottom, as you can see im water cooled but for some reason i tried 2 blocks, swiftech and EK both caused major lock ups , EK .5mil step in the block , swiftech, not touching vmr's...
now i had to rma my ocz m84 pcie drive, it deff will not fit now i have these monsters in here, so i will have to sell and buy a reg ssd....
unless heres question 2, anyone know of a mobo i can fit everything on inside a cooler master cosmos? and still have crossfire?
heres my specs...
i975 E @ 4.3
Gigabyte UD5 - (microcenter didnt have the UD7 and i needed a mobo asap)
6 gigs Dom triple
PCIE M84 SSD
2x 5970 ( 1 asus 1 xfx)
1000 watt Corsair
On a side note i got through 3dmark vantage with no problems 35000 score - also did OCCT for 20 mins
heres some pics:
heres my specs...
i975 E @ 4.3
6 gigs Dom triple
PCIE M84 SSD
1000 watt Corsair
heres some pics:
