the hdmi port has audio pass through,you could use the dvi to hdmi adapter
you also need to switch the default sound device to your hdmi connection as well.
I hooked up one of those last night.
I changed the setting in windows 7, and the mixer showed sound was going to the device.
I have:
Realtek HDMI Output that's the one I was using.
Realtek Digital output.
ATI DP Output - This is an option, but it won't let me enable it.
I'm using the WHQL 10.3
check in the drivers.. there should be an option in there for enabling the audio on the card its self if im not mistaken..
the ATI DP output is for the display port audio only..
and you can use the DVI ports as well aZn you just need a DVI to HDMI cable..
Correct, I thought the layout of the 5970 is the same as the 5870 which has a native HDMI port.
Also, I don't think an aftermarket DVI -> HDMI cable would transfer audio, the included DVI -> HDMI adapter does something to the signal so he'll just need a regular HDMI cable and use the adapter from my experience. ( I could not enable the audio using a DVI -> HDMI cable, until I purchased the adapter then it worked pretty flawlessly. )
I have:
