The fan on my 5970 has started making hideously loud noises when oriented normally. (If I turn the case on the side so the fan isn't being pulled down by gravity, it works just fine) My card is out of warranty, so I can't RMA it.
Does anyone have any suggestions for either a new place to buy one of these turbine fans that fit into the ATI Radeon cowl, or some other aftermarket cooling solution? I've heard horror stories about the 5970 Arctic Cooling Xtreme, but I can't even find one of those, let alone any other product.
Thanks in advance for any suggestions...
