thank you.... googleing it got me lots of ways to do a xt but not a 5900Visable-assassin said:![]()
Enjoy![]()
ryuji said:i have a question.. the top variable resistor is for core voltage right?
ryuji said:one more question.. reading my voltages its 1.56 for core and 2.75v for memory (flashed it with 5950 bios)
how high can i go before its gonna die fast... i want it to last 2 years or so
54YW4T said:Is this what you are looking for:
http://www.cluboverclocker.com/guides/5900_Flash_Mod/
i have already gone and tried out about 50 bios's this one does the most voltage for memory(if memory changes at all) and core54YW4T said:Is this what you are looking for:
ryuji said:i have already gone and tried out about 50 bios's this one does the most voltage for memory(if memory changes at all) and core
my question is my cards currently running at 1.56 for core and 2.75v for memory killabee said that was the max i would want to do even with physical modding... is there any more it can go and still last about 2 years at most? im trying to squeeze every last bit of preformance out of it
I(illa Bee said:well its a gambel...but i would not recoment it... and really, once you get to 1.55-1.57v the gains in MHz are minimal.....you get the most Clock gain form the first few .1 volts added...
its not to you benifit...for more preformence start playing with drivers....also try upping you AGP clock speed...helps me a bit, most top out at 80Mhz..
