I'm currently running a BFG GTX 280 OC2 (overclocked to around 285 speeds), and managed to snag a Sapphire 5870 Vapor-X off of Newegg. After looking at about 10 different reviews of the 5870, there seem to be mixed opinions as to whether it's a worthwhile upgrade from a GTX 280/285. I bought the 5870 because I've started to notice that the 280 can't quite keep up a solid 60fps in some newer games at 1900x1200, 4x AA (e.g. L4D2, Serious Sam HD, etc). However, if I'm going to drop $400 on a card, I'd like it to have some staying power.
Any opinions on whether I should keep it? Would adding a second 280 be a reasonable option on a Corsair 750TX power supply? I'm a little wary of SLI because of the stuttering problems that have plagued multi-card configurations in the past...
System Specs: Core i7 920 @ 3.7GHz, HT on, 6GB memory
