Infaustium
- Apr 16, 2008
- Is there any difference in visual quality when under the Standard tab, the "Use Custom Settings" option is set to Performance instead of Quality?
When setting AA/AF to "app controlled" in the CCC, it's not possible to move the "Standard" tab slider to either Performance or Quality. It's automatically set to Performance.
When trying to set it to Quality by un-ticking the "Use Custom Settings" box, it then re-sets the AA/AF settings to not being app controlled, so there's no way to keep it on Quality when AA/AF are set to being app controlled.
Since that's the case, I wanted to know if that affects overall general visual quality.
Thanks.
Thanks.
