5870 + Video capture card
killerc4
I recently bought this capture card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5523203&CatId=4957
when I stream anything 480p and under, its perfectly fine, runs well. If i try to do 720p or 1080i I will get no video. I opened the stream using Virtualdub I can see the 1080i stream when I use the preview (nothing shows up using overlay).
This lead me to believe that its an issue with my video card (XFX 5870). I thought I would try to turn off overlay, but the included media center program does not have the option. I tried to find an option in the ATI control center but no luck.
Any help would be greatly appreciated, thanks!
After much MUCH testing I have narrowed the problem down to my motherboard...
I have a EVGA x58 SLI,
I have tried the card in all slots, updated bios, reformated.
I tried the card in my spare pcs, and it worked fine in all of them, in XP and windows 7.
The only thing I can think of is that it is my motherboard so I will try my luck in that forum.
