I just got a 5870 crossfire setup up and running and its acting up big time. I started off with some TF2 in eyefinity at 5760x1080 fine, it seemed kinda jittery but was around 130 fps constant with tons of aa. That was ok. Then I tried Crysis on one screen at 1920x1080 and bam, I'm greeted with what looks like some kind of asynchrony between the two cards, everything is spazzed out and flickery, the best way to describe it really is that it looks like my 5870s got in a big fight and are jerking back and forth trying to tear the screen apart. I searched online for 5870 flickering issues but none of the issues I found seem as serious as mine. Putting on vsync doesn't fix it, but makes it a bit better. Putting it in windowed mode makes it run perfectly however?!
problem summary: screen in all 3d games looks like crossfire couldn't decide what resolution to render; it flickers rapidly between full resolution and what looks like a 75% resolution and horizontal tearing and banding is visible; problem occurs at 1680x1050 and 1920x1080 but not below only when displayport is used, everything works fine at 1776x1000, and when disabling crossfire, going into windowed mode, and using a dvi cable instead. occurs with all driver revisions between 9.12 and 10.1 beta; issue is likely not PSU related because windowed mode is entirely stable.
Here's my system spec
phenom 965be stock
Asus M4A79XTD EVO
Corsair HX620
Sapphire 5870
Gigabyte 5870
- both vanilla
WD 1TB HDD
3xdell p2210h displayport-dvi-dvi
EDIT: Update: well displayport strikes again. I disconnected the monitors and tried a single monitor in DVI, voila, it worked. Single 5870 - no displayport funny business - Double 5870 - displayport goes wonkers. I'll try getting a new cable, but damn. Stupid thing sucks!
EDIT2: some tags for the unlucky few that might also have this problem "5870 crossfire problems" "5870 crossfire tearing" "5870 crossfire flashing" "5870 crossfire flickering" "5870 crossfire high resolution problem" "5870 crossfire displayport problem"
