SeaFoam
- Oct 13, 2004
So I was thinking, all of us that run eyefinity are running big resolutions - what do you think the performance difference in games would be (like Arma 2)?
If I already own a 5870 1GB, I could buy a 5870 2GB down the line and have them work in crossfire for a total of 3GB, correct?
Assuming they are the same clock speed.
The 2GB card will perform exactly as a 1GB card. The extra GB of ram will be wasted, as the way Crossfire works each card holds exactly the same information in the ram.
GRRRRR. Seriously that's retarded.
