5850 vs. 5870 for 1920 res.
Megalith
24-bit/48kHz
Currently waiting for either of these to come back into stock at Newegg, but now I'm on the fence as to whether to go for the 5850 or 5870.
The new system I will be building will probably be paired to a display that will run at 1920x1200 (or 1080 if I decide to make it an "HTPC")---with that considered, would there be any benefit to getting a 5870?
We'd have to know the rest of your system specs. 1920x1200/1080 is high enough resolution to see a noticable difference between the cards but it really depends on your necessities and other system hardware. What will it be used for, what will you be pairing with the card hardware wise, stuff like that.
I'd have to agree to the response, thus far. the rest of your system specs, required level of AA/AF, and the games you play would be useful.
I picked up an XFX 5850, but the rest of the parts are still coming in, so I haven't gotten to use it, yet. I game at 1920x1080...the overall factor for me was price/performance. Your situation/needs may not be the same as mine... but you have not said, as of yet.
I use a 5850 and have yet to come across a game I can't run very well. Warhead runs at all Enthusiast with 4x AA, Far Cry 2 can run DX10 Ultra High 4xAA (I might be able to get 8x, but I haven't tried). I can max out GTAIV. So if the rest of your system is similar to mine you are probably safe with the 5850 unless your really want to play Crysis/Warhead at high AA settings.
I agree with Derangel. From the reviews I have read 1920X1080 does not make much difference on the scores between the 5850 and 5870 (except maybe Crysis Warhead)
Thanks, folks.
The system will be an i7 with 6 gigs of ram.
I'll be happy if I can run Fallout 3 at max settings (full AA and distance, etc.) at 1920x1080.
considering bloomfield is the fastest single piece of CPU silicon out there, it only makes sense to match it with the single fastest piece of GPU silicon if you want to look at it that way...
But I don't. The extra $150 on an HD5870 over an HD5850 sure does give you a slim return. You can check out the exact specs here. for that extra $150 (~45% added cost) you get an additional 18% memory bandwidth and raw pixel throughput (by clock speed, meaning any self-respecting [H] forum member would be able to get that back no trouble :cool:), an additional 25% texture fill rate and, most importantly, an extra 25% general shader performance (both the later figures are by a combination of lowered clocks and incap'd transistors).
I'm not really a big gamer and I don't need to max out everything so I decided that the HD 5850 would be good enough for 1920 x 1200 in my situation.
oveclocked it can run anything out there.
only game not maxable would be crysis.
but a 5870 dont max it either.
Thanks, folks.
you could get by with a 4890 then. it would do that for you and will be easier to get right now. get it now for a buck fifty and wait until you need the 5850. otherwise you are def 5850 category. no reason to pony up the extra unless you are looking at eyefinity.
