Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I currently run a i7 3.8 with 2 5850s in crossfire, I am wondering if it would be worth it to sell the 5850s and get one 6970? Will I see an increase in performance? Thanks.
If we posit the following as true:
One 5850 is roughly equal to one 6870.
One 6970 is roughly equal to two 6870s.
Then one 6970 will perform about the same as two 5850s.
Albeit with improved tessellation and MLAA capability.
As far as FPS goes though, I don't think you're going to see more FPS from a single 6970 vs two 5850s.
