- Jul 11, 2001
Currently I'm running my 5820k @ 4.5Ghz using 1.35v with an H100i GTX and 4 fans in push-pull. That is 125 BCLK and a multiplier of 36. I'm using the 125 BCLK mainly so my memory can run at it's XMP speed of 3000Mhz.
I was running Prime95 and had CPU-Z open on a 2nd monitor. I noticed that it was running at 4250Mhz, at a multiplier of 34 (though still showing a range of 12-36). Temps never broke ~65C on even a single core while this was happening,
I quickly tried several games, and during all of them the CPU clocks up to 4500Mhz as it should. I tried using several versions of 3dmark, running the CPU tests, all of which are able to peg all 12 logical cores to 100%. The CPU bumped up to 4500Mhz just fine with those tests also.
I went back to Prime95 to do some testing, and this is what I found:
Using 1 Prime95 thread, the CPU clocks up to 36 (4500Mhz)
Using 2 Prime95 threads, the CPU clocks up to 35 or 36 (4375-4500Mhz)
Using 3 Prime95 threads, the CPU clocks up to 35 (4375Mhz)
Using 4 Prime95 threads (or more), the CPU clocks up to 34 (4250Mhz)
This seems to only be happening in Prime95. No core temps ever went above 65C during this testing and they were mostly much lower. Any ideas why it seems to be throttling in Prime95, since it doesn't seem to be temperature based? I recall something about Xeons throttling when AVX was used, and I think this version of Prime95 uses AVX. Is that relevant to what is going on?
