- Feb 26, 2005
I just picked one of these up at microcenter today for testing purposes. I have it running in my x470 gaming plus max motherboard using a beta BIOS and CL14 3200MHz memory with a stock wraith cooler. Preliminary testing at 85W PBO limit is:
randomx: 8.7khash/s (about the same as my other 5800X) (xmrig)
raptoreum: 2.75khash/s (xmrig)
Avian (AVN): 14.5khash/s (cpuminer-opt rplant fork) I've only had this running for a few minutes on 15 threads. Switched to rplant to see if that would improve things and it dropped to 11khash/s (probably due to variable difficulty).
Haven (XHV): I haven't been able to get it running but others report around 2000-2100khash/s.
Temps aren't great, 78C, but this is all I really had handy in terms of coolers and I wanted to keep it somewhat similar to the cooler I have on my regular 5800X for comparison purposes.
I want to try out Dero as well since apparently that can use up to 20MB l3 cache per core but I think this is enough for tonight.
[Update]
Finally got around to haven mining. Hitting around 900-940h/s but I think I'm thermal throttling too much (hitting 91C). Also have a week's worth of data for raptoreum mining and the 5800x3d is about 10-20% better than a regular 5800x. These aren't exactly the same setups though since I have the 5800x3d (80W TDP limit) in a 1u case and it's hitting 91C while the 5800x is in an open frame hitting 79-80C. I'm rearranging everything but once I'd done with that I'm going to try to work on improving the airflow in some of my 1U cases, which I think will help the 5800x3d a little bit (definitely losing hashrate in monero with it, for example).
[Update]
