just received my his 5770 with the new egg shape cooler. plugged it in my system and fired it up. its performance was great. but i was shocked when i looked at the temperature. it was at 88~89C (91C max!
room temp only 20C) after running about 20min heaven benchmark. i said wtf??? my diamond 5770's max temp was only about 58C in the same system (same room temp).
i immediately suspected the cooler was at fault. i tried re-seating the cooler but it didn't help. so i swapped the coolers of both of my cards (i took out the egg shell cover in the process). the result actually quite surprised me. the his cooler without the egg shell cooled even better than the diamond cooler. it brought down the max temp of the diamond card to 56C. while the his card with diamond cooler reached only 61C max. so i swapped the coolers back, leaving the egg shell cover off. my his card was down to 59C max! that's 32C difference here!!!
i was totally stunned! i guess the cover is keeping the heat inside the cooler. how could the manufacturer made such a bad design?
then i replaced the heatsink compound with AS5, the max temp was down another 1C to 58C. while idle temp was only 34C (it was 44C before taking off the cover). so i suggest all of you his 5770 owners with the egg shape cooler to take out the cover and see if you can make your card cooler or not. maybe other brand with the egg shape cooler are the same too. worth giving it a try too
