cerwinvega
- Jun 15, 2004
Building a semi-budget gaming rig for a friend, as follows:
AMD Athlon II X2 240
GIGABYTE GA-MA785GM-US2H
G.SKILL 4GB (2 x 2GB) DDR2 1066
GIGABYTE GV-R577D5-1GD-B Radeon HD 5770
Antec earthwatts EA500
Western Digital Caviar Blue WD6400AAKS
ARCTIC COOLING Freezer 64 Pro
All but the GPU arrived last week, so I got the basics together running with onboard vid, and was easily able to push the 240 to a 12hr prime stable 3.5Ghz.
GPU arrived today, so I reset everything to stock, and installed the card.
Decided to heat it up with a little 3DMark06, and about two thirds of the way through the very first test, I get the following:
http://forums.amd.com/game/messageview.cfm?catid=260&threadid=114093
(Picture is in the 2nd post. That's from a 4850, but that picture is exactly what I see here.)
Hard reset required.
OK, so, I figure maybe I screwed up the driver install or maybe the card wasn't seated properly..or w/e, so I reseated the card, checked the PCI-E power plug connection, and did a full driver sweep and reinstall of the only available 5770 drivers from the AMD website.
After rebooting, I also rechecked the fans etc, all looked good.
Getting ready to try running 3DMark again, I brought up CCC to monitor temps in between tests, provided I could get through the first one of course.
Which I was not able to do, as it hard-locked with the same vertical lines again....*sigh*
wtf, let's see if ramping up the fan helps at all...I mean, everyone else seems to be getting great temps with this card, but, it's worth a shot right ?
I manually set the fan speed to 55% and it hasn't hard-locked since. Temps in the mid 70's or thereabouts.
So with a big WTF, I come to the [H] for ideas.
RMA ? Wait on drivers ? EA500 not enough ? What do you think ?
