the tin tub
- Dec 15, 2009
Hello HF
I recently OC'ed my Q6600 from 2.4 to 3.2 thanks to a new heatsink and some help from you folks. I tried to put a small OC on my GPU via MSI Afterburner but it overheated with anything approaching a decent OC, even with a custom fan profile. (I was at about 890 core and 1290 memory and it was still overheating) Part of this is likely due to poor case airflow, but I have 2 new 120mm fans I will be replacing my old worn out ones (which spin pretty slow now) with to help with that.
So my question is how the devil do I set up some better cooling for an XFX 5770 itself? I've seen people claiming to have over 1ghz of core clock speed so there must be some sort of solution out there. I tried to do some looking on google but I had trouble finding anything too helpful. Lots of pictures of completed custom cooling setups but no guides or explanations.
Is it as easy as applying a CPU heatsink? All I had to do for that was dismount the mobo and add a bracket to the back of it, then toss the heatsink itself on top and add a fan, which was a breeze. (Wordplay!)
