5700G max resolution @ 60 Hz
Google can't find the answer
• What is the maximum resolution of the 5700G @ 60 Hz ?
• Is DisplayPort a function of the CPU/APU or the motherboard ?
A single 4k at 60hz can be done. Not for games tho.
Display port and HDMI will be found on the motherboard
Now I need to find a mobo that will support DisplayPort at 4H 60Hz !
all of the msi b550 boards have it, the asus tuf boards do too. BUT it is limited to dp 1.2, think its an apu thing but it will do 4k/60.
Easy enough to find. B450, B550, X570, X470 motherboards all have their fair share of selections based on your budget
