560Ti 1GB, 2GB or Radeon 6950
Discussion in 'Video Cards' started by TechnoMage, Mar 20, 2011.
  1. TechnoMage
    TechnoMage [H]Lite
    74
    Dec 23, 2002
    I'm building out a new Sandy Bridget Computer with a 2600K, 16GB of memory and a SSD for my main drive. It will be hooked up to two 1920x1200 monitors.
    My original plan was to get a GTX 560 Ti like the MSI Twin Frozr for $250 but I was worried about it only having 1GB of memory. Then I starting thinking about the Palit version that comes with 2GB for $280.
    Now I'm wondering if I should just go with something like the Sapphire Radeon HD 6950 for $277 that comes with 2GB.
    Thoughts?
  2. niomosy
    niomosy Limp Gawd
    247
    Nov 21, 2005
    Might consider paying a few bucks more for the XFX 6950. Lifetime warranty has its merits.
  3. Brackle
    Brackle Old Timer
    7,179
    Jun 19, 2003
    6950.
    You can unclock it to a 6970, and save yourself alot of money.
    The 560 TI isnt nearly as fast as a 6970.
  4. SpeedwayNative
    SpeedwayNative n00b
    19
    Mar 4, 2011
    With that res, I would personally go with the HD 6950, especially if you have multi-monitor gaming plans!
  5. JohnleMVP
    JohnleMVP [H]ardness Supreme
    5,251
    May 20, 2001
    I'm assuming you'll only be gaming on one monitor at 1920x1200 so you won't really need more than 1GB over video memory. If you want eyefinity/NV surround then definitely get a 2GB card.
    I think the GTX560Ti is a pretty solid card for a single monitor.
    As for the 6950 I would get the cheapest reference card design if you want to unlock it into a 6970.
  6. Lord_Exodia
    Lord_Exodia [H]ardness Supreme
    6,997
    Sep 29, 2005
    For single monitor @ 1920x1200 it's a toss up between GTX 560Ti and 6950. It will depend heavily on the game and what IQ settings you plan to use.
    I guess I'll recommend the XFX 6950, be sure to buy a reference model to unlock to a 6970 and lifetime warranty FTW.
  7. TechnoMage
    TechnoMage [H]Lite
    74
    Dec 23, 2002
    I appreciate the comments. Let's assume, that gaming will be confined to one monitor while the other screen will have up a webpage or email client. Let's also assume that while I'm not uncomfortable with minor overclocking, stability in the end is much more important. I also do some development on this machine.
    Is the 6950 locked with the extra price?
  8. Superhuman
    Superhuman [H]ard|Gawd
    1,037
    May 19, 2006
    6950 is the better card.
  9. Zion Halcyon
    Zion Halcyon 2[H]4U
    2,101
    Dec 28, 2007
    How can one ensure they are buying a reference model of the 6950's?
  10. Stupac
    Stupac [H]ard|Gawd
    1,349
    Jul 27, 2006
    Extra cost not worth the price merits?
  11. TheToE!
    TheToE! [H] Brewmaster
    6,528
    May 17, 2005
    I am in a similar situation. I want to spend $200-$250 on a single card. I'm buying a new SB setup soon. 1 monitor, 1080p res. Seems like a lot of options right now. I tend to be leaning towards the 6950 right now, but what are your opinions?
  12. AthlonXP
    AthlonXP [H]ard as it Gets
    20,237
    Oct 14, 2001
    6950 all the way...
  13. TheToE!
    6,528
    May 17, 2005
    1GB vs 2gb? 6950 vs 6970?
  14. aldamon
    aldamon [H]ardness Supreme
    6,505
    May 24, 2000
    For the OP, I would pick the 6950 2GB. The 560 seems a bit displaced with the cheap 460 1GB still on the market and the insane unlocked 6950 2GB. Also, 2GB 6950s have been dirt-cheap after rebate lately ($230 - $240.)
    For TheToE!: The difference in performance between the 1GB and 2GB 6950 is basically zero until you unlock and overclock (additional voltage) the 2GB card. The 1GB version is $205 + shipping right now so hard decision.
  15. Vittra
    Vittra Gawd
    891
    Jul 9, 2005
    All 6950 2GBs are still reference for the time being.
    The 1GBs however are non-reference.
  16. Bankie
    Bankie [H]ard|Gawd
    1,512
    Jul 27, 2004
    I've had both the 560 and the 2GB 6950. The 560 was a tad faster than the 6950 in every game I play. Now that the 6950 is unlocked and overclocked it's a little bit better than the 560 was at this resolution in most of my games.
    After having it for a while I'm a little disappointed simply because it doesn't have the power to max out some of my games at the "low" resolution of 1680x1050 (Rift, Metro 2033, etc.)
    http://hardforum.com/showthread.php?t=1588960
  17. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
  18. niomosy
    niomosy Limp Gawd
    247
    Nov 21, 2005
    I'm content with the extra cost on the XFX for the warranty knowing there's a fair chance I'll end up making use of it.
    For those with no such worries, certainly the cheaper card is the way to go.
  19. blackhawk777
    blackhawk777 Limp Gawd
    386
    Jun 10, 2010
    Not true and never was; The reference cards have a RED fan on the end of the card as opposed to dual fans or a fan in the middle, and they will be stamped "AMD" near the PCIE slot connector. XFX, Diamond, HIS, Sapphire, Gigabyte, VisionTek, and Asus all have reference model 2GB 6950s available to name a few.
  20. boushidosan
    boushidosan Gawd
    547
    Dec 19, 2010
    OP please tell us you have decided to go with AMD :)
  21. TechnoMage
    TechnoMage [H]Lite
    74
    Dec 23, 2002
    Thanks all for the advice. In the end I decided to go with the 6950. Here's the full order I placed with NewEgg last night.
    Case: Cooler Master HAF X
    Motherboard: MSI P67A-GD65
    CPU: Intel Core i7-2600K
    Fan/Heatsink: Corsair CWCH60
    Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) (I got two of these for 16GB total)
    Video Card: Sapphire Radeon HD 6950
    Power Supply: Corsair CMPSU-850TX
    OS Hard Drive: Mushkin Enhanced Callisto Deluxe 240GB
    Data Hard Drive: Samsung Spinpoint HD204UI 2TB (I got two of these)
    Optical Drive: Lite-On 24 X iHAS424-98 DVD writer
  22. blackhawk777
    386
    Jun 10, 2010
    Nice work; that machine is going to be killer (and it is very similar to mine :cool:).
    My setup:
    AMD HAF 932 Case
    MSI P67A-GD45
    i2500K CPU
    16GB RipJaws
    2x XFX 6950 2GB
    2x Intel X25-M 80GB (raid 0)
    3x WD RE3 250GB (raid 0)
    Corsair 850HX
    Dell 22" Panels (Eyefinity 5040x1050 setup)
    Anyway, well put together and good luck with it.
  23. trandy1001
    trandy1001 n00b
    1
    Mar 24, 2011
    I'd say go for a 6950, congrats on the purchase
