5600go in an alienware
LittleMe
So I got the 60.72's installed on my alienware after using a mod'd inf and I went looking thru the options. So I now have the Clock Frequencies tab, which currently shows my settings on Performance (2d) which is 180/360. I then have Performance (3d) which is 275/360. Now, if I click detect optimal frequencies, it runs thru some tests and gives me 342/635. Now, thats a biiig change. What should I set it at? Are any of you using one of these?
I really know jack shit about that chip, but maybe it is clocked so much lower than it could go for heat reduction? Dunno, it would just worry me. And those drivers are beta IIRC, so they could be just fucked up.
