Hi, I'm having a very serious issue with my rig for a long time now.
I got the PC assembled recently by a computer shop, all parts brand new.
Ever since I got it, I had the same 2 problems regarding the video card:
1) occasionally (when NOT playing games), my screen will black out for a few seconds, come back with an error in the bottom right corner saying "nVidia driver 2xx.xx has crashed and recovered)
2) when playing games, after half an hour, an hour, 2 hours or sometimes more, my whole system would just freeze, and the sound will freeze in a loop as well, and all i can do is a physical restart. This happened with all the games I tried playing.
Naturally, I assumed the video card was defective so I RMA'd it. Got a replacement. Same problems. RMA'd entire system this time. After a total of 2 months waiting time, I got my system back and was told that the video card is fine and so are all the other components and that they had it running fine for 48 hours. Well. clearly they haven't tried playing games on it because the above problems STILL persist.
I tried ALL recent nVidia drivers, currently on the most recent one.
So it seems none of the parts are at fault (they are all brand new).
Yesterday I noticed that my GPU gets slightly hot after a few hours of gaming. Can that be the problem? when my PC boots up, it's at around 36 degrees and slightly rises, but generally doesn't get over 43 when not gaming. Now, when gaming, after some time it gets up to 65 and more, which is when I think my system freezes. Is this normal or may this be causing the problem? if so, how can I reduce temps?
Also, a friend suggested that a clean install of my OS might solve the issue, which I find hard to believe.
The card is MSI 560 ti twin frozr ii/oc
case is coolermaster haf 912
power supply is antec neopower 650 watts
8gb kingston hyperx ddr3 1600mhz ram
crucial m4 64gb ssd
1tb seagate barracuda hdd
win7 home edition 64bit
Please help me out here, I've been having this problem ever since I got the rig, which cost me nearly $1500 in total and I can't even play any games on it... (for extended periods)
crucial m4 64gb ssd
