560 TI display as 560?
cpthk
I just got my asus GTX 560 Ti, but I do not see any place on the box say it's 560 Ti. I only see it says GTX 560. It has the clock speed of 925Mhz on the box. Even after I install the nvidia official driver, I check my device manager, it is still showing 560 not 560 Ti. Is this normal?
Thanks.
look at the white sticker on the back, i bet it says
ENGTX560 DCII TOP/2DI
where did you buy from?
check the sticker on the back like procyon said.
i've seen people getting gtx 560's labeled as gtx 560 Ti.
i think the customer support guys told him it was because they put a different sticker on a different card.
Go to Nvidia and use the auto-detect.;)
GPU-Z should tell you exact card you have or just type in system information from window and expand display.
Just to update, they sent me the wrong card. There is a sticker put on by this online retailer says 560TI(not the one with S/N on it by asus), but the card is actually 560. I contacted them, they agree to replace for me. Thanks everyone.
In the future you can use the Nvidia control panel which will show you how many CUDA cores it has. This will help you figure out which "560 you" have (336 VS 384 VS 448 if I am not mistaken) as well as clockings, VRAM, BIOS version, driver version, ect.
Just go to the top, Help, system information.
Shady retailer trying to pull a fast one. Make sure you post a review for the product and review them on those business ratings sites around the web. Yea they agreed to replace it, because they got caught and don't want to get sued or have someone tell nvidia what they're doing. But you can bet that you are not the only one they did that to, even if you're the only one who noticed.
