550BE overclock question(voltage)
dorky82
Just got my CCF with 550BE.
Currently running 3.990 with 1.485 voltage.
Overdrive reports 1.485 voltage but CPU-Z reports 1.512-1.528
Which one is right?
Also is this safe voltage?
temperature is 30'c idle.
either way the voltage is fine.. your under the 1.55v recommended limit.. as long as the processor isnt overheating.. you should be fine.. but id lean more toward cpu-z being right.. overdrives probably showing the CPU VID voltage..
