55 - 60 inch display
shadowj
Hello everyone,
My 55 inches Samsung ( KS7500 ) is dying, I'm looking for another one, 55 - 60 inches
It should be 4K, curved, MVA panel
What would you recommend, guys ? I'm playing 95 % flight simulators
Money isn't an issue, right now.
Thank you
I'm using a Samsung Q7F, it is very nice. There is a curved version I believe.
Samsung QLEDs are wonderful.
I'm using the Q9FN 55" and am honestly gob smacked at how good it is.
Unfortunately I dont think they do a curved in the Q9FN series but if you can find one in another range, you wont be disappointed.
Here you go for this year 2019 ranges
https://www.samsung.com/uk/tvs/all-tvs/?ultra-hd-certified-tvs
There are a few curved among those. Be sure to check they are QLED versions.
edit:
Hmm when selecting QLED only there are no curved versions.
But when I select curved only, that produces no results so its worth checking from the original link I provided to be sure there are no QLED curved versions.
From what I can easily see, the only curved are the NU series which are not QLED.
As I havent seen any of these I cant vouch for how good they are but they might be just what you need so are worth finding a place to view.
You might do well to get a 2018 or 2017 TV if the price is right, my TV has reduced substantially in price in just a few months!
Note this years Q** series have half the lag of the 2018 versions, but at 14 to 28mS they were very good anyway so still worth considering.
There are also new 8K versions with HDMI 2.1. Not full bandwidth but enough for the TVs purpose.
Thanks, Nenu
What about the burn in / retention?
One quick off topic question, please :
I have an issue with my Samsung UE55KS7500
I think it's the One Connect Box the culprit
I have another Samsung UE49JS9xxx
Are they ( One Connect Box) compatible?
